please tell me its not a head gasket
Old 01-05-2012, 02:32 PM
  #51
drumrush's Avatar
Originally Posted by josh135
i have an 08 2.2 and i replaced the head gasket and it will not run now. ive taking it apart 4 times thinking i had it out of time but its in time. ive checked every sensor everything!!!! i thought maybe i bent a valve but valves are fine. has anybody ever ran into this problem?
No idea. Try starting a new thread under problems and service
Old 01-05-2012, 02:34 PM
  #52
josh135's Avatar
how do you do that?
Old 01-05-2012, 02:39 PM
  #53
1LowLS's Avatar
well you need 3 essentials to have an engine run.Compression,fuel and spark.Check those.Your not getting one or all.
Old 01-05-2012, 02:42 PM
  #54
josh135's Avatar
well dont you think i know that!
Old 01-05-2012, 11:16 PM
  #55
kxrida2000's Avatar
obviously not lol ur **** dont run
Old 01-05-2012, 11:30 PM
  #56
1LowLS's Avatar
Old 01-05-2012, 11:32 PM
  #57
drumrush's Avatar
tehehehe
Old 01-05-2012, 11:33 PM
  #58
nhanson's Avatar
lol
good ole CSS
Old 01-06-2012, 02:08 AM
  #59
kikal8's Avatar
ha ya. wat kind of oil do u use. its more than likely just water. i see it occasionally at work, the cap gets this yellow goo on it. but yea.. i think ur alright. a leaky head gasket would definitely cause atleast some white coolant smelling exhaust.
Old 01-09-2012, 08:24 PM
  #60
2007cobaltsc's Avatar
That headgasket test kit will tell you for sure. We use them at work and they work like a charm, just ensure a good seal between your coolant reservoir and the rubber cone on the glass cylinder of the tester.
IMO, that just looks like condensation, also can be caused by a failing/failed thermostat not allowing the car to heat up efficiently or even at all, as well as short drives with no problems with your car at all.
Old 01-09-2012, 10:52 PM
  #61
bluebalt07's Avatar
Take the head, set it on its side, and turn the cams over with a wrench while shining a light through the intake and exhaust ports. If you can see light around the valves then they aren't closing all the way and your not getting compression.
Old 01-09-2012, 11:16 PM
  #62
badbaltguy's Avatar
as long as you're running a full synthetic oil you'll be fine even if its a small leak. synthetic mixed with coolant doesnt break down & turn milky and lose its viscosity. of course that has its bad sides too, since it dont mix and burn off, it just keeps building up and sooner or later it will find its way out and thats not fun to think about.
05-28-2022 03:47 AM
ineedacobaltss
11-07-2015 02:25 PM
Trav3480
10-01-2015 08:17 PM
09-28-2015 12:51 PM
SlowSaturn
09-28-2015 11:03 AM
Quick Reply: please tell me its not a head gasket
