Popping out of gear?
I was driving home from my girlfriends house tonight, and for the first time ever it just Popped right out of second gear. So naturally i put it back into gear, it goes in fine, no problem, then i press the gas, POP right back out again. WTF IS GOING ON? anyway have an idea?
Used to happen to my eclipse all the time, but only for 5th gear, traded the car in for my cobalt before I could figure out what the problem was. How many miles does your car have?
Sounds like gear synchros to me too. Happened in my old 3000GT and was a fairly common problem with them, happens in my buddy's 07 Civic Si but it's a known problem with them too. Might need to look into rebuild/warranty work.
If it is only 2nd it could be 2 things. If it pops out when you INITIALLY shift it in or occasionally grinds it is a linkage cable. If it popped out when it was already engaged (ie no movement while your driving) then it is probably a syncro.
My 2nd gear pops out sometimes when I initially shift into 2nd. Anyone know how to fix or adjust a linkage cable?
