Power Door Lock problems
I just bought a 2006 LT for a commuter. I noticed the key fob (only got one) wasn't working before I bought it, I just figured it was the battery. I went to replace the battery and I noticed one of the contacts that holds the battery is disconnected from the board. I tried the new battery anyway and got nothing still. I'll probably try to solder it back on as I have nothing to lose. If I get a new fob, can I program it myself of is that something I MUST go to the dealer to get done?
The lock/unlock buttons on the door also does not work. I found no dead fuses. Is this an issue related to the FOB or should they still work regardless? If they should, where should I start? Thanks for any help.
Pull the handles and make sure the buttons are coonected in the door. Also I'm not sure where the fuse for power accessories is, but did you check underhood and in the cabin fuse boxes?
I looked over all of the fuses I though could be even remotely related and they all passed my visual test. I have yet to take the panel off, I've only had the car for a day. I have to assume they are connected, but stranger things have happened I suppose. I'll probably check that out this weekend.
There's a panel under the hood and a fuse panel passenger side center console down by where your feet would normally go
Also get a fuse tester, much better than visual
Ok, well this is probably important. I just realized there is a lock/unlock button on the passenger door which does work. The drivers side does not. I don't know how I missed that switch. So I guess I'll order one for the drivers side and see if that is faulty. As far as the key fob goes I guess I'm stuck with the dealer.
Am I safe to lock the doors with the button and unlock them with the key? I know some cars don't like that and will set off the alarm. I didn't know if the cobalt had such a thing.
I've sort of been finding that out the last couple days. Locking them manually is a pita, too. I just hope I can get this key fob working to save a trip to the Chevy stealership. Because who knows how much it would cost to get one programmed.
agentirons
10-16-2015 02:11 AM
