problem with rear defroster
o **** ill check that right now thanks for the pics
does any body now what the number is? i looked at rer de fog and there none in there
did your rear defroster ever work? its possible that whoever tinted it may have scratched one of the main lines for the defroster, causing the whole thing not to work
If the control is saying its on and the fuse/relay is good. Then you could take a volt meter and put the leads on each side of the rear glass defroster lines (be careful not to scratch the lines). This will tell you you have power to the defroster and the problem maybe a broken line in the glass. If you dont get readings then its something between the relay and the rear window causing the problem.
well i dont have a volt meter handy.im taking it to the dealer, but i had a jet chip installed wich fryed my computer so they replaced the ecu could that have done something? and yes it did work i have had this car for about a year and a half so it has worked. the newsest things ive done to this is that new ecu,and i installed after market windows?
sorry aftermarket window kit (power windows) but they called and said it was a relay thats bad so is that the fuse relay or what. the total with that and new speaker 182.00
k so got the relay. they were going to charge me 182.00 for the relay and blown speaker. went to see how much the parts were 16.00 for relay and 25.00 for speaker laughing at them for labor priceless.
DANRICKARD
10-01-2015 12:08 AM
Delta coupe
09-30-2015 08:11 AM
