problems with power steering
In the past week and a half my power steering keeps cutting in and out, it'll stay on between 10 to 30 minutes of driving then goes out, i restart and it goes back to normal. Then some times it goes out right away, could this be a blown or loose fuse? or is there something wrong with my steering colum? Im gonna be checking it out later today, figured i would get some insight from u guys that might of had a simular problem.
open up your fuse box and look towards the back on the left side. see the cables coming off the box? those are the power source for the power steering, at least if i remember correctly. check to make sure that everything there is tight.
and please don't shock yourself.
and i feel your pain man, when my ignition control module was in the process of taking a dump the ******* power steering wouldn't work. and it chose the best days to cut out too. like 90 degree temps in a black car.
hot and sweaty+ no power steering = awful commute
