Random Misfires
Old 05-30-2016 | 04:48 PM
SpeedyGonzalez's Avatar
Unhappy Random Misfires
So i have been getting misfires between 2~2.5 RPMS. Check Engine Light came on checked the code P300 (Random Misfires). I have replaced my plugs. I checked my ignition coils and they seem okay. I pulled my MAF out and cleaned it. While my MAF was out it seemed to be running the same so i thought maybe it was the MAF so i went and bought one just in case. I put the old one back in and i checked the CEL and i pulled a MAF code. I bought some Seafoam and used it on the car and seemed okay at first but as i try to WOT it misfires pretty bad. Got home checked the CEL and i pulled the coded and im back to P300. Any suggestions?? Oh and i just put the Seafoam in. Do i run it a little more to see if itll get better or is it an immediate fix??
Old 05-30-2016 | 05:53 PM
Canadia's Avatar
Lnf? How many miles? Ever have the valves cleaned?
My guess is valve gunk
Old 05-30-2016 | 06:02 PM
yeah it is LNF. its got 195k miles?? dont remember exactly but something like that and no i dont think its ever had the valves cleaned. i havent anyway im not sure about the previous owner
Old 05-30-2016 | 06:31 PM
Wow an lnf with 195k miles, trying doing a compression test what are your plugs gapped to?
Old 05-30-2016 | 07:33 PM
Sl0wbaltSS's Avatar
Seafoam isn't going to do anything to the intake valves on a Direct injected car lol.
Old 05-30-2016 | 08:58 PM
Leak down test and clean your coked intake valves and valve runners
Old 05-30-2016 | 09:07 PM
i have not tried doing a compression test but i think im gonna have to now that you mention it. Better safe than sorry and im gapped at ~35
Old 05-30-2016 | 09:13 PM
sorry about that i got my cobalts mixed up. ive got an LSJ not an LNF
Old 05-31-2016 | 12:09 AM
Yeah just do a compression and leak down test the gap seems to be correct not very familiar with the lsj tho
Old 06-05-2016 | 12:25 AM
So i did a compression test and the leak down. Compression test Cylinder 3 & 4 were about 180-185ish while 1&2 seemed to be ~200. So when i did a compression test cylinder 3 was okay but cylinder 4 wasnt. The air seems to be coming from the fuel injector area or the spark plug hole not too sure. Any suggestions??
Old 06-07-2016 | 11:15 PM
anyone??
Old 06-09-2016 | 10:24 AM
jdbaugh1's Avatar
Originally Posted by SpeedyGonzalez
anyone??
Are you saying you can feel/hear air coming out somewhere when you do the compression test?
red s s
18
08-24-2016 07:26 PM
freakta
04-05-2016 11:05 PM
SSxTc0825
03-29-2016 11:20 AM
prettypink
03-14-2016 12:10 AM
09SS7163
03-10-2016 01:30 AM
