Rattling up front, steering rack or something?
Old 04-13-2009, 06:05 PM
Rambotk3's Avatar
it would be cool if someone could get a how to up on replacing the swaybar endlinks. My 36,000 bumper to bumper warrantee is over, but could this be covered any other way. I still have the powertrain but i didn't wasn't sure
Old 04-20-2009, 07:35 PM
jerrodmann's Avatar
so they replaced the steering column, it WAS NOT the problem.
"well we called GM and they said that's what the problem was" idiots. I told them day one about the sway bar linkage, they just blow it off. They keeping the car over night and should hear something tomorrow on what they think it is now... lemon laws here i come...
Old 04-20-2009, 07:42 PM
jsscooby's Avatar
I have similar trouble. swaybar endlinks were replaced with no resolution.
Old 04-20-2009, 07:56 PM
Htown2200's Avatar
im having similar issues
Old 04-21-2009, 11:23 AM
bboyfreeflow's Avatar
the endlinks being replaced did help alot......but there is still a slight rattle sometimes...with the rack.......as well as some weird sqeak sometimes
Old 04-21-2009, 06:06 PM
jerrodmann's Avatar
they tighten some things under there. thats exactly what he said. idiot.
Old 04-21-2009, 06:37 PM
JaY DuB's Avatar
same happened to me about 1yr and change... it wound up bein a blown strut and twisted sway bar linkage..i also rode around on a blown strut for about 6 months...real bad news
Old 04-21-2009, 07:22 PM
who??? are u talking to
Old 04-22-2009, 01:39 AM
ziggity's Avatar
I have a rattle up front I can only hear it if i turn the wheel back and fourth while driving or hit a bump, I can kinda feel it in the floor to when it happens
Old 04-22-2009, 01:41 AM
Jesse_Chouinard's Avatar
I'm going to say endlinks aslo.....Had the same prob. on both my balts!
Old 04-22-2009, 01:46 AM
  #36
Haz l33t wheelz.
ls1fbody's Avatar
Originally Posted by bboyfreeflow
i think there is only stock end links..but i just replaced mine today.. they are 37.50 each, and that was the main rattling noise
powergridinc.com, look around, they have some for the cobalt, 159.99 and you will never have that issue again, especially on a lowered car.
Old 04-22-2009, 01:49 AM
  #37
jschatte's Avatar
Its not that bad...
1. take off wheel
2. loosen the nut on the top and bottom (18mm), you will need a wrench to take off the bottom nut.
3. if the nut spins hold the other side with some vice grips, it doesn't matter if you wreak them, they are going anyway.
4. If the nut is not moving try soaking it with some WD-40 or something
5. Remove the endlink and install the new one.
Old 06-12-2009, 09:32 AM
  #38
Donny Brasco's Avatar
I have a 2009 Cobalt SS Sedan with the same issue that is being talked about here.
So do we have a consensus, is it the endlinks or the shaft?
I am going to try to get this fixed at my next oil change....
Is there a TSB number associated with this seemingly common problem...????
Old 06-12-2009, 09:47 AM
  #39
replace the swaybar end links. thats the main rattle.. althought i stil lhave a little bit of a rattle over bumps sometimes,but its normal with my lowering springs and ****.
Old 06-12-2009, 09:53 AM
  #40
Haz l33t wheelz.
ls1fbody's Avatar
powergridinc.com
the SS ones are only 10" compared to the rest at 12" the shorter ones would be a better replacement.
Old 06-12-2009, 10:18 AM
  #41
Bad site? Could not be retrieved?
Solaris99
28
03-15-2017 01:22 PM
jimbofug007
10-02-2015 12:06 PM
SSLOW06
10-01-2015 07:21 PM
Tupp
09-30-2015 08:18 PM
Quick Reply: Rattling up front, steering rack or something?
