Rear Springs Install
Old 11-08-2015 | 01:44 PM
Cuda009's Avatar
I'm installing a new set of Sportlines in the rear of my 2008 SS and having trouble getting them in. I have the shocks undone at the bottom but can't compress the spring enough myself to get it into the mount. I got a spring compressor from down the street but the spring won't in with the compressor on the spring. How can I get these springs in place? Thanks!
Old 11-08-2015 | 01:56 PM
double clutch's Avatar
You dont need a compressor. Once you let the axle drop, theres plenty of room to get the spring in by hand.
Old 11-08-2015 | 02:14 PM
Cuda009's Avatar
That's the problem though. The axle is not dropping enough to easily get the springs in. It drops maybe two inches at the very most and that's with somebody pushing down on the axle with me trying to get the spring in.
Old 11-08-2015 | 04:24 PM
That's weird I was able to do the swap by myself. Might sound stupid but you aren't supporting the car anywhere near the axle right?
Old 11-08-2015 | 04:32 PM
Cuda009's Avatar
Jack stands are on the mounting bracket where the axle/torsion bar mounts to the body of the car.
Old 11-08-2015 | 04:35 PM
CobaltSS 16's Avatar
Hey Cuda... i think i know what your problem is. Unbolt the bottom bolt on the shocks on BOTH sides... the rear beam will drop completely with more then enough space. sounds like you are trying to do one side at a time.
then seat the springs correctly and use a jack to jack up the rear beam and put the bolt in the shocks back in.
Old 11-08-2015 | 04:53 PM
Cuda009's Avatar
Shocks on both sides have the bolts removed. Pic below gives an idea of how little the axle is dropping. This is a brand new shock that's in place and where it is in relation to the hole it goes in.
https://drive.google.com/file/d/0BxH...lhRmNEQnc/view
Old 11-08-2015 | 06:00 PM
Move the stands forward more. Push the axle down and forward towards the front of the car. The only thing that holds the axle in place is the shocks. As long as those are unbolted, it should move freely.
Old 11-08-2015 | 06:38 PM
Cuda009's Avatar
Dumb question, but where else can I put the jack stand in the rear of the car?
Old 11-08-2015 | 06:54 PM
I put them on the plate where the bolt that hold the axle up it should be on the way at that point
Old 11-08-2015 | 06:59 PM
Cuda009's Avatar
That's where they currently are.
(not my pic)
Old 11-08-2015 | 07:00 PM
I put mine just in front of the bracket that mounts the axle to the body. Should be completely out of the way there.
Old 11-08-2015 | 07:02 PM
That's where they currently are. (not my pic)
Thats fine then. You could try to loosen the thru bolt on the axle bushing and see if you can get it to drop.
Old 11-08-2015 | 07:15 PM
Yup that's where I put the stands at
Old 11-08-2015 | 07:53 PM
Cuda009's Avatar
Does it need to be oriented in any special way assuming it's going to rotate when I loosen it?
Old 11-08-2015 | 07:54 PM
I dont believe so. I didnt have to loosen it. Mine dropped easily. You could spray some lubricant i there also.
Old 11-08-2015 | 07:56 PM
Cuda009's Avatar
WD-40'ed it already.
Old 11-08-2015 | 09:36 PM
Idk then. I had zero issues with my lsj and it has over 200k on it. My lnf was fine too.
Old 11-09-2015 | 07:33 AM
Staged07SS's Avatar
Administrator
Administrator
TRY LOOSENING THE AXLE BUSHING BOLTS (SORRY FOR THE CAPS).
The bushings can be stiff and stick.
Old 11-09-2015 | 12:15 PM
Cuda009's Avatar
Is this the same bolt mentioned above that runs through the center of the bushing?
Old 11-09-2015 | 12:23 PM
Yes the same ones i said. You can see them in the pic
Old 11-09-2015 | 09:42 PM
Cuda009's Avatar
Loosening the bolt at the axle bushing dropped the axle plenty far enough for the springs to pop right in. Thanks everybody for the help!
Old 11-09-2015 | 09:44 PM
Cool thanks for the update man
Old 11-09-2015 | 09:59 PM
Glad it worked out for ya.
Old 11-10-2015 | 07:08 AM
Staged07SS's Avatar
Administrator
Administrator
Great!! Glad it worked.
Raptor285
12
11-11-2015 11:10 PM
Marcov223
11-09-2015 12:16 PM
E4Overlord
North Pacific
10-23-2015 10:30 AM
10-22-2015 08:18 AM
E4Overlord
10-21-2015 11:09 PM
Quick Reply: Rear Springs Install
