Recalls/TSB Info on these problems?
I recently got a paper in the mail about the recall for the power steering on my 06 SS/SC. Should I take this in and get it replaced even though i've never had a problem with it? Or does it only apply to people having this problem currently?
Also my valve cover gasket is leaking oil, I read it was a TSB, will they fix this for free as well (or are they supposed to I should say..)
Recalls are free. TSBs are NOT free by any means. TSBs are only a way to advise technicians of a fix for a common problem.
Take it in for the recall. Its a simple inspect/modify or replace the PS motor... I can't make heads or tails of that recall and I've yet to do one. I'd just take it in and get it handled.
1 Post
Per the Power Steering: Yes, it is a free fix. It is a voluntary recall. The fact that you got a letter means that your car is affected by the recall. You want to get it replaced before it becomes a problem.
As far as valve cover gasket:
http://www.crateenginedepot.com/stor...P1775C142.aspx
