" reduced engine power"
Old 11-12-2015 | 07:32 AM
DylanMcniven47's Avatar
Exclamation " reduced engine power"
Hey guys, I just put a new motor in my car with 92k, it was all going good when it was running again & then it randomly read a code that said " Engine power reduced" and it started spitting &a backfiring a bit. Anyone know why?
Thanks in advanced
Old 11-12-2015 | 09:20 AM
tuned08ss's Avatar
Is there a CEL?
Old 11-12-2015 | 09:50 AM
Tykuura's Avatar
only time I got an "engine power reduced" error the car wouldn't start.. but it did spit and stutter when i rarely got it to run
that was from a MAP/fuel/throttle sensor with a faulty wire harness. car worked fine after I reconnected the wiring without that sensor
although I assume you didn't modify anything recently?
Old 11-12-2015 | 02:36 PM
exninja's Avatar
Check codes. Eng Power Reduced should have stored a code.
First thing I suggest is check your grounds. A loose ground caused that for me.
Corrinaannajo
11-21-2015 10:54 PM
CobaltSSTC
11-11-2015 10:30 PM
Pitbull2o08
10-31-2015 01:38 PM
horsinround1974s
10-23-2015 08:41 PM
Sean Cummings
10-18-2015 10:17 PM
Quick Reply: " reduced engine power"
