Repeated park lamps fuse blown
there have been no aftermarket mods--the first time it went out I replaced the fuse and it
it went for a week before it happened again. It does not appear to be a hard short or it
would blow the fuse right away. I did find a tsb #3385a which was dated 01/01/1901
summary (repeated park lamp fuse open). Hopefully the dealer can get additional
info as to the cause since I can not get any info on the tech service bulletin.
i actually had the same problem about 3 days ago. what i found out was my intake was hitting the headlight wires. what happen was the wires where touching the intake and it was shorting out. i wasted like 8 fuses trying to figure out the problem. it also blew my high beam fuse to. so watch out with those wires.
