Replacing cams
Replacing cams
I recently replaced my cams in the 2.2 ecotec. Now after reassembling some of my valves are being held open when the cam is in the closed position.. Yes i did mix up the cam followers a bit. Any solution to this problem???? Thanks in advance.
??? Yes, take it apart and put it back together properly???
Not quite sure what you're really asking.
