Roll Pin gone agen!
Old 05-30-2006, 09:39 AM
06black's Avatar
Roll Pin gone agen!
Well it seems like I happen to have a car with more trans problums then most cobalts put togather.
As some might remember i think i was the first or close to being the first 2006 SS/SC to blow the trans a while back but i later found out it was the roll pin in the linkige.
well its happend agen and agen and agen(sp?)
while cruzin down I-75 friday night i drop down in to 4th to pass a truck, when i pop off the clutch the tach swings over and the cars doesnt go any wear so i start to freek.
i try all the other gears and i can only get 2nd and 4th so i drive the car home and to work and back all ****** weekend with 2nd and 4th due to the lack of a 2nd car.
it was one of the scaryist things i've ever had happen to me while in a car, when all of a sudden you cant get power to the ground.
its in the dealer as of 8am today for the 5TH ROLL PIN!!!!!!!!!!!
isnt that total bull ****!!!!!!!!!
any ideas on what might be causeing it?...any idea on how to stop it from breaking agen?
the dealership wants to drill the part out and put a bolt thro it but they cant unless GM says "OK" to that idea.
I'm pissed! i seem to not have my car for at least a 3-5days a month!!!! for a series of repeting problums.
rant over!...what do ya'll think?
EDIT------------------
in the past i thought it might be caused by the B&M but for the whole 1-2 months i had this roll pin in there i never put the B&M in so its not that.
Old 05-30-2006, 09:42 AM
3fo893013L's Avatar
god damn dude. your broke it again? jesus.. Lemon that bitch!
Old 05-30-2006, 09:43 AM
06black's Avatar
thats what i'm thinkin BUT i sooo dont wanna have to take ALL the aftermarket **** outta the car but i'm lookin into the law rite now.
Old 05-30-2006, 09:48 AM
3fo893013L's Avatar
strip it and drop it off. Pick up an 07.
Old 05-30-2006, 10:03 AM
06black's Avatar
I might have to....once this gets fixed i think i'll be takeing **** off the car to get it redy for this..
COME ON PEOPLE!!! theres like 50 views GIMME YOUR thoughts!
Old 05-30-2006, 10:08 AM
BLKSS's Avatar
I would refuse to make anymore payments. Return it to your dealer and shake up a **** storm.
Old 05-30-2006, 10:11 AM
06black's Avatar
The problum is i totaly dont wanna get rid of this car...to attached to it BUT in my better judgement its lookin alot like thats the rite thing to do.
i'll have to get it back this time and make it stock agen.
UGH!
Old 05-30-2006, 01:22 PM
06black's Avatar
Old 05-30-2006, 01:30 PM
RACIN_RANDY's Avatar
insteed of them using a "roll pin" tell them to use a "solid pin", that might help insteed of them using a nut & bolt.
Old 05-30-2006, 02:02 PM
06black's Avatar
the problum i'm runing in to with that idea is the fact that the dealer can only replace it with certon parts so THEY dont void the warrenty.
the servis maniger has called the tech dept of GM to see if he can get it authorized.
i can only hope!
Old 05-30-2006, 03:58 PM
jokieman's Avatar
i can only hope!
You don't want to go that route man, Once they start screwing with the car like that, you're liable to wind up with more problems, and if you ever try to take it to a different dealership, your warranty will be null and void. Nobody's going to want to work on it after this dealership jimmy rigs your car.
Take it to a different dealership. And request that they either fix it right, replace the whole transmission etc. If it happens again just lemon the damn thing.
5 times is about 4 times too much. I have to wonder if this dealership isn't doing the install wrong, or messed something else up the first time around.
Old 05-30-2006, 05:47 PM
2K5SS/SC?'s Avatar
Pull out the Lemon Law on it. If my car had the same problem three time, I'd definately be all over the Lemon Law, but it's always a different ****** problem! I am on the same page with you bro. Good Luck.
Old 05-30-2006, 09:48 PM
06black's Avatar
well the cars fixed!!...all in one day!!!
they got the fix athorized by GM so they put a nut and bolt thro it and its a legit GM fix.
Old 05-30-2006, 09:53 PM
RaineMan's Avatar
Under the Lemon Law they only get 3 attempts to fix the problem. Make 'em buy it back and grab yourself a '07.
Old 05-30-2006, 09:55 PM
jokieman's Avatar
Eh, I think it's too late now that he authorized them to do the jimmy rig, and accepted the car. Unless it happens again, but more than likely whatever was causing it to break so often is going to put stress on another part now and he'll have to start all over again.
Old 05-30-2006, 10:12 PM
05BlackCobaltSS's Avatar
yea, i just have a feeling that it's more than just the roll pin...something is putting some serious stress on it and causing ti to break. I'd DEFINITLY make them buy it back and put an order in for an '07!
Old 05-31-2006, 08:37 AM
codyss's Avatar
I have yet to see this problem elsewhere so I would assume it's driver error or your car has another problem.
I have missed 3rd hard and havent even bent the linkages or pins.
Old 05-31-2006, 11:21 AM
06black's Avatar
as far as makeing GM take the car back thats a def possibility BUT i'm going to waite at least a month or so so i can have my plant maniger buddy get me the car in a day or two.
also if there is something else causeing this problum them it'll prob brake the bolt they put in and i'll worry about that problum when it arives.
Old 08-23-2006, 10:35 PM
fastSS06's Avatar
Just now saw thisthread...yes i know it's old...but I have already had one roll pin shear off, and to my great luck it just happened again yesterday.
Old 08-23-2006, 10:43 PM
06black's Avatar
WELCOME TO MY WORLD!
mine kept breaking untill they put a bolt in insted of a oem roll pin.
works great now!...nothing else has broke eather!
Old 08-23-2006, 11:26 PM
eastcoastz's Avatar
Well after 3 weeks and a lot of fighting I got my car back today with a new Roll Pin. They were about to rebuild my trans for a shift lever Roll Pin.
Old 08-24-2006, 12:56 AM
06black's Avatar
I'm SOOOO suprised they went that far into the trans with out looking for other issues.
they just wanted to jump to conclusions and charge ya for it...total BS
Old 08-24-2006, 01:45 AM
fastSS06's Avatar
I just got done replacing mine.....**** GM.....I'm not waiting 2 weeks for my car like last time. So i just did it myself, with a stronger roll pin
only took me 2 hours
Old 08-24-2006, 02:21 AM
06black's Avatar
good man...way to go!
what did u use?
Old 01-03-2007, 04:41 PM
srt-killer's Avatar
What kind of pin did you use?
Quick Reply: Roll Pin gone agen!
