security learn for zzperformance lnf pcm.
has anyone done this procedure ?
ran through the procedure, car does not start.. security light is now out tried removing the pcm and reinstalling the original but the security light is still out to try and relearn again..
wondering if anyone else had the same problem and what you did to correct it....
will have to give zz a call again, spoke with someone else and it seems it learned the security code since the security light is out, he suggests that maybe the vin was iccorectly installed, the outside tag is correct..
May be able to get it scanned locally to check vin...
there is an alternate procedure.
turn the key on without starting the car for at least 11 minutes, following that, attempt to start car, it may start, if it does not, repeat procedure two more times, your key is now learned.
