Shitty american made oil filters
This is a picture of 2 different filters. Both are straight from the dealer. The parts manager told me that they often vary where they are made.
On the left, made in Bulgaria. On the right, USA. I have no clue what happened to it. I have not done anything different since I have owned the car, as far as oil changes go.
What is to blame for this?.. The shitty filter or is something wrong? Also, I know that it may appear to be ripped, but it is not, the little fins are just all out of whack.
They gave me another american filter yesterday at the dealership, so if it happens again, I'm blaming the filter.
If you do some looking, you'll see that this has been occurring with Ecotecs for quite some time. I recall that originally people were blaming it on certain brands and recommending using only AC Delco filters. It looks like it was compressed and is now shorter than the filter it's next to. If that's the case, then the element being cut to the wrong length at the factory wouldn't be the cause. Another possibility is the filter cap being overtightened, but I don't think you could go tight enough to compress it that far. Perhaps it collapsed from oil pressure. It seems like this has occurred with most of the filter brands. There is only a handful of factories that actually make oil filters anyways, so many of them are probably coming from the same place.
And those are tied!
Ive had the same issue with napa golds and switched back to oem and never had a problem.
I think it might be from the O-ring sticking in the bottom of the holder and the filter twisting from removal.
Make sure you put some oil on the O-ring before installing ,it may help.
