Slow rolling windows?
#39
The passenger side only slows down if you use the drivers side or sunroof at the same time. I remember it having something to do with the power windows and sunroof on the same circuit. The more glass you move the more it loads the circuit and in turn less voltage to the passenger side.
#41
i have a 08 did the exact same thing, now everytime i try putting down the passenger side it blows fuses. been to dealer twice they say theres nothing wrong with it. so lotsa luck with yoursd
#42
#43
mine is an 05 and lately it takes FOREVER for my passenger to go up its at the point where i dont even roll it down because im scaryed it might not go back up its that slow but im a college kid and broke so i cant be fixxing it right now o wells
#44
my 08 sport passenger goes really slow too the sun roof and driver are fine but the passenger takes forever to close and its annoying i dont remember it going this slow when i got it dec 07 but i cant remember how fast it went then
#45
Could be a problem, Maybe it isn't Dont know for sure.
But yes, my passanger window is noticably slower then my
Driver's side.
-Jonathan
#46
My pass window is very slow even with the car running and using the passenger switch. I replaced it with a used window motor & it worked for oh about 1 year?? now its back to sloooowwwwwww mode. I try not to lower it much.
#47
so after the dealer could not find the problem with the fuses going i had Latka take a look at it and he found a short in the switch on the drivers door, fixed it now they work great
#48
Me too... i put both window motors on the dyno and my drivers side window is putting out 350in/lbs of torque and the passenger side is only making 280 .. i'm gonna call GM and see if they are releasing a Stage 1 upgrade kit for the window motors ya ya i know i'm lame but i'm also bored at work ...
