Some Problems (steering wheel, vibrations)
Hey guys, so about a month ago I got all new tires (had a flat and just replaced them all) and got an alignment.
Ever since then I always have to hold my steering wheel to the left slightly to go straight. What would be causing this?
Also, recently while driving between 60-70 mph my car has been vibrating (feels like driving on deflated tires), but it doesn't happen all the time and sometimes it is worse then others.
Finally, while breaking sometimes my car also vibrates. I know this might be the rotors/brake pads, but what is
an easy way to check that. Could the rotors also cause the vibration while just driving and not breaking?
The car is a 2005 2.2. I am in need of an oil change, but I don't think that is related.
Thanks for your help!
If you have to turn the wheel to go straight it was a bad alignment. The vibration could just be a unbalanved wheel. Either a weight feel off or they suck (cause your car pulls also)
Steering wheel off center - bad alignment, need to re-align
Vibration - caused by unbalanced wheels and/or high road force, shops with hunter roadforce aligner can fix that for you
Brake shutter - to check either if it's front or rear, apply parking brake and go for a drive and brake, if the shutter goes away chances are it's your rear brakes, otherwise fronts
