Speed wobble..
It's most likely an out-of-round (flat-spotted) tire that you're noticing at low speeds. What kind of tires are you running? If they're really soft tread compounds, they tend to flat-spot until they're hot and then round out.
HMMM... I will have to see if I have my hubcentric ring still intact. If they aren't there that could be the problem, where would I pick up a set if they are missing? These sit right between the wheel and the hub correct?
I had a similar problem when braking, steering wheel would shake. Their are metal clips on the lugs that hold the rotor on, if you change wheels/rims they need to be removed. Took care of my problem.
ThoR294
10-04-2015 08:44 PM
z28addiction
09-28-2015 12:03 AM
