Speed wobble..
Old 09-15-2009, 01:27 PM
DomDiggity's Avatar
mine does the same thing but it also does it when i take off????
Old 09-15-2009, 01:34 PM
06G85's Avatar
Yes, as stated above, it's warped rotors. Get them replaced and the pproblem will be fixed.
That's wheel hop Buy Ingalls
Old 09-15-2009, 01:35 PM
DomDiggity's Avatar
have one its not wheel hop its wobbles when i accellerate from a stop
Old 09-15-2009, 01:41 PM
Illini_06SS's Avatar
It's most likely an out-of-round (flat-spotted) tire that you're noticing at low speeds. What kind of tires are you running? If they're really soft tread compounds, they tend to flat-spot until they're hot and then round out.
Old 09-15-2009, 01:56 PM
DomDiggity's Avatar
they are barum bravuirs 2. it wobbles with acceleration and coming to a stop
Old 09-15-2009, 01:57 PM
rickdarris2004's Avatar
HMMM... I will have to see if I have my hubcentric ring still intact. If they aren't there that could be the problem, where would I pick up a set if they are missing? These sit right between the wheel and the hub correct?
Old 09-15-2009, 07:48 PM
Jesse_Chouinard's Avatar
yep, I picked mine up at a wheel shop
Old 10-15-2009, 02:39 AM
06BaltCoupeLT's Avatar
I had a similar problem when braking, steering wheel would shake. Their are metal clips on the lugs that hold the rotor on, if you change wheels/rims they need to be removed. Took care of my problem.
RaginChopsuey
10-27-2015 01:27 PM
ThoR294
10-04-2015 08:44 PM
Extremespeed
09-29-2015 04:34 AM
ThoR294
09-28-2015 05:31 PM
z28addiction
09-28-2015 12:03 AM
Quick Reply: Speed wobble..
