sputtering at a standstill?????
My car has a barely noticable sputter when I.m sitting at a standstill,it goes away when I start moving,could it be plugs,injenfilter maybe the CA cat???
I haven't been following what the best plugs for you guys are. As long as it is in the proper heat range you will be ok. NGK is one of the top quality plugs and call your dealer and ask them for the proper gap for your application (mods).
had the code read and I clogged the ca dp already,this causing backpressure and random misfire,so can I gut the cat??? or should I put my stock one back on??????
