Steering wheel shake while Braking!!!!
Got the car with 67k on it now at 77k and it was shaking a little when I got it but now its gotten worse.
2008 2.2 Lt
Thinking its the Front rotors......
Sound about right to you guys??
If so then Im just going to get rotors and pads since it will all be apart anyway.
2008 2.2 Lt
So the either way by doing both pads and rotors that has got to fix the problem
Anybody know anything about Callehan Rotors and pads?
I've had the same problem too. Changed my front rotors, as they were warped on the inside. Also changed my brake pads from ceramic to organic. For both these options, I went with the cheapest brand available.
Most of the problem is fixed, I do still feel it shake sometimes a bit when there's a lot of brake dust on the rotors.
My input, don't go cheap on the pads. You can get a great set of pads for $50, and they make a huge difference. Rotors will be ok unless you are going very high end, there isn't much gain. But cheap ass pads can ruin a set of rotors and are just in general sucky to have.
Raybestos PG pads are great and reasonable, i've used them on a couple of my cars and never had issues. Better than any crappy pads.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Another issue is not many say Rear drum only like this one
It concerns me that they have to be specific to my car because GM sucks and gave me rear drums
when u change the rotors and pads make sure to clean the rust and **** off the hub clean and regrease the sliders and get the rust and crap out of the caliper braket and antisieze where the pads touch the braket. if u do all that, and not get lube/antisieze everywhere i guarentee u good solid shake free noise free braking. its just a proper service instead of just slapping them on.
Im Having the same issue right now with my SS/TC, i put SS/SC rims on it an they had a shake at 60MPH so i took them off the next day and ever since ive had a vibration only when i brake. could it be a tie rod or alignment issue before i spend an arm and a leg on rotors?
Problem solved picking up parts in the morning.
Damn pass front break caliper was locking up apparently the dealership knew it and just replaced the pads before they sold it cause the pads looked brand new. The car had been doing it since I got it but very little at first and then got worse.
This is why I love my Cobalt and my repair knowledge, after taking it apart and looking bam cheap fix compared to the dealership.
No not all the time, sometimes it will and sometimes it won't. Now i have a small shake at 60MP/H. its not bad but its noticable and annoying. any ideas? Sometime i get a noise which sounds like its coming from the front right caliper. ill have to take it off and look at it
2008 2.2 Lt
2008 2.2 Lt
Yes so true
