steering wheel shakes under heavy braking
Old 10-21-2007, 07:38 PM
outtamymind's Avatar
Originally Posted by Novajoe
The only way a rotor isn't going to make contact with the caliper is if the caliper is stuck or something else like an abs modulator that's not allowing the caliper to function properly. Otherwise there is usually constant pressure in the brake system making the calipers clamp togeather... just not much until you step on the brake pedal. If a rotor is warped then it's not going to affect the steering wheel as long as the caliper is functioning properly. That's cool that you work in a chevy dealership and all but I've been there too. I've got my ase's and such. My basement garage is probably better equipped then most private shops.
CobaltCoupeCrazy actually explained it the way i should have my mistake but thats basically what i was trying to say. and ya i had my rotors turned at 5000km and i don't brake very hard. they're just crappy rotors.
Solaris99
28
03-15-2017 01:22 PM
ineedacobaltss
11-07-2015 02:25 PM
biniecki
10-25-2015 02:23 PM
TedSS
26
10-10-2015 04:30 PM
09-26-2015 06:44 PM
Quick Reply: steering wheel shakes under heavy braking
