Steering wheel shaking under braking?????
Like title says however I know most are goin to say warped rotors which I recently had. When the rotors were warped the wheel would shake horribly at 70 and not at all at 40. Within the last 1500 miles I had the rotors turned. Within the last tank of gas or so the shaking has returned however at 70 the brakes are completely smooth when braking from 40 to 25 the wheel shakes. Is there something else other than the rotors that could cause this ? Oh by the way I have a 07 sc/ss
^^^ This, or improper torque on the lugs. Worth breaking out the torque wrench and retorquing them.
Could have warped the rotors again too, going to be easier to do after you remove material by having them turned.....
replace rotors and pads at the same time get wheels balanced and see what happens if it still shakes have your front end inspected and check lug tq specs. I use a tq stick specified for smaller cars like ours so not to over tighten the lugs which can cause warping to the rotor(s) try out what we suggest and report back.
Good luck,
-Matt V.-
Good luck,
-Matt V.-
shacking to much money out of pockets
i got a 08 lt cobalt that is perfect never had any problems except.... the f*(kin SHACKING!!!..
i got both new front brakes drilled n slotted, ceramic brake pads, two new front end hub bearings had wheels were balanced n weighted. got new back brakes to just because...People tell me that its my rotors but they brand new and i keep money into it and it keeps shacking .... could it be my SWAYBAR LINKENDS-ALIGNMENT!??!!!....can someone please help me i got air and everything is good but it wont stop shacking and i dont know what to do but at this point im gunna trade in .... cause i love my car but cant stand it at the same time!!!!!!!!!!!!
No offense, but no. I am a certified mechanic and that won't do anything.
First check tire pressure, if ok then take the wheels off and inspect pads, rotors, and calipers. You could have a fluid leak or air in the system which will cause pulsating peddle and or shaking.
good luck.
