Steering wheel vibration when braking not from warped rotor...
Sorry for bringing this back from the dead but did you ever solve your vibration problem?
Have you checked your axle shafts? I believe that is my problem so im going to try to swap them out and see if it goes away.
okay well I went to my mechanic and I'm convinced im could not be my brake rotors as i recently replaced my worn oem brakes with r1 rotors... So i spent 1000 dollars fixing worn bars and links which made my steering study for about 2 weeks... Then it came back with a vengeance! it got so bad that I begin to worry if the vibrations would cause other problems in the car. I went immediately to the dealership and purchase the OEM rotors and had them installed with new ceramic pads. it has been about 3 months and my steering is 99.9 percent free of wobble.
it was hard for me to accept the fact that the r1 rotors I had purchased just months prior where are the actual cause of the wobble.
at least this may be a free lesson (which i paid dearly for) that I can pass on to you guys.
