stock injectors in gm stage 2 car
Im having a problem with my car threw a "injector circut open cylinder 2 open code". i replaces the injector harness and ive swapepd injector and the code stays on the same cylinder. I can for the life of me figure this out. But something i was goin to try was just switch all the injectors back to my stock ones which i know are good my question is can i hook the stock injectors back up safley (just plug them back in and go) all the car has done to it is a gm stage 2 kit (Pully, injectors, tune). i just dont want to damage anything and have it lean out on me. i dont have the money right now for new 42's and i dont plan on running it hard i just need to make this code go away so i can get it retagged. so does anyoen know if i cant do this or will i have to get it tuned for them again? any help or suggestions will be appreciated Thanks
also idk if this matters but the car runs fine no misfires or anythign just that stupid code so i cant pass inspection, if anyone know a way i can get it through delaware insection without fixing it idk bypass it somehow or something like that anything would be helpfull
if you have a stage 2 and put the stock injectors back in you may have to get it re tuned. or you can try and unplug the battery and wait about 30 minutes, drive around and see if the code comes back.
brickloaf
09-06-2015 05:55 PM
NoBalt123
09-04-2015 07:10 AM
