Stock SS/SC running lean after oil change?
Helped my brother-in-law change the oil on his 05' SS/SC on my lift the other day, and after the change he got a CEL. A friend used a scanner and told him that is was running lean, cleared it, and it came back after a little driving (he didn't tell me exactly what code it was). The car is completely stock, so its not an intake or something causing his a/f ratios to be off, and he told me the car is running better than it has in a long time. Any idea what would be causing it? He hasn't changed his fuel filter yet (32,xxx miles) so I was thinking that could be the problem, but it seems odd that the code only threw after the oil change? Is there a vacuum hose or anything in that area I might have pulled off trying to get the filter out? I have an LNF so i'm not very familiar with the LSJ layout. He told me he could feel a nipple that was screwed onto the bottom of something that felt like it should have a hose, but couldn't find a loose hose anywhere.
Thoughts would be appreciated, I'm going to take a look at it one of these days if I get out of work early enough.
There are alot of hoses and a sensor connection right around the oil filter canister. You could have easily knocked one of the hoses loose, or loosened the connection on a sensor while doing the oil change.
There is actually a connector that I always had to unplug to get the socket and extension on the filter cap. Maybe he forgot to plug that back in ..... or disturbed something taking the filter out.
Getaway_Driver
40
09-10-2015 09:11 AM
09BlkCrusader
09-09-2015 04:47 PM
Getaway_Driver
09-08-2015 09:41 AM
