Supercharged: where have all the power gone?
check around for any vaccum lines that could have gotten knocked off while they did the oil change. make sure all connectors are connected.
Ok well, I don't know where the boost module switch is but here's another thought. The oil filter is kinda buried in there and it's hard to get to. Is it possible that something was unplugged to make room to get to it? Then of course, reconected, screwing up the boost?
Haz l33t wheelz.
if anything check your supercharger maybe its the cause of the problem not gaining its boost the pulley form the supercharger is probably causing the drag and mobil 1 not as good as you think royal purple notice a difference check the supercharge oil maybe its dry thats causing the low performance
Yeah...mobil 1 and royal purple (walmart has it now). I'm on pennzoil synth and it's pretty good as well...don't use Q, never use Q
