think i blew a head gasket
#79
Although i cant ohysically see any obvious breaks in the gasket. There are some areas of question and i got opinions on it. It was a leak small enough to only allow combustion air into the cooling system and a very tiny tint mount of coolant was noted in the oil
#80
Well, everything is cleaned up. no damage anywhere els..
head is being machined by the best shop in town, only herd good things about these guys for YEARS. $170 for that
And knowing a guy that works at GM gets me my 35% off, lol. Headgasket and headstuds be here monday. $190 for that
oil and antifreeze, another 50. should be running tuesday.
#81
last thing i would like to ask from you guys is, and i cant find it anywhere. on here or google.
how do i set the timming?
and i need all the bolt specs for the headstuds, and all other head related bolts that are torqued
#88
when i spoke with a few of the mechanics at gm, they all agreed once i told them my symptoms and everything that happened, no flow, coolant being pushed out through the surge tank when cap off, coolant lines blowing up like baloons when i cap it on, how long, and different methods i tried to burp the system, etc its my headgasket. ok, i mentioned bringing it down there to get it tested, and they are like, yea sure if you want... you can pay for a tow and we can take your money and tell you what we just did. a local mechanic said the same thing, and i can describe what went down the best i can, but you guys dont see it first hand, the headgasket idea was floating around my head for quite while when messing with the car. And i did find some other evidence once i opened it all up
09-28-2015 12:51 PM
