Throw Codes Please Hellp
0304 cylinder 4 misfire
0171 system to lean wtf is that ?
1182 ??? can find this code anywhere ?
more codes to come i believe the cobalt is fucked
Heres some info for you
Inspect the wiring harness of the BARO sensor for the proper connection.
Inspect the wiring harness of the SCIP sensor for the proper connection.
Disconnected, damaged, or incorrectly routed vacuum hoses
A supercharger or engine vacuum leak
A misaligned, loose, or damaged air intake duct
Any objects blocking the air inlet probe of the mass air flow (MAF)/Intake air temperature (IAT) sensor
Any contamination or debris on the sensing elements in the probe of the MAF/IAT sensor
Any damage or fractures to the SCIP sensor housing
A missing or damaged SCIP sensor seal
Restrictions or debris in the SCIP sensor vacuum port
Inspect the throttle body and the throttle valve for the following conditions:
Any damage
Any restriction that could affect the air flow through it
A vacuum leak at the throttle body
Any missing parts
A throttle valve that is not fully open when the accelerator pedal is fully depressed
Any damage
Any missing parts
