Throwing three codes...HELP!!
So my car is drivable, has no hiccups whatsoever. But my check engine light keeps coming on and I keep throwing three codes, my aeroforce reads them as follows...
P1101
P2228
P2261
I thought it was the fuel selenoid in the engine and it has since been replaced, that didn't fix the problem seeing how I am throwing codes again.
Anyone have any ideas???
P1101
P2228
P2261
bump anyone else? ive been told its a sensor on the gas tank but apparently the sensor is 800 dollars by itself, money i really do not want to spend right now, anyone else have this issue?
p1101 is a calculated airflow problem. p2228 Is a baro sensor problem. p2261 Is the supercharger bypass valve stuck closed. It is unlikely that the first two codes caused the p2261 to set. But its very possible that the p2261 caused the other two codes to set. So you should take on this code first. Check all the vacuum lines going to the bypass valve, make sure none of them have cracks or tears in them. and make sure they are all connected and tight. If you can easily turn them or pull them off they should be replaced. The valve itself could be bad or the actuator.
