Ticking noise during boost
So I have been hearing a ticking noise when I get to about 10-15 psi. Only seems to happen when the car heats up because it was sitting out in 100 degree weather for about 6 hours and it did it but later that night the sound had disappeared once the car had sat and cooled off. Took it to the dealer once already and they replaced the vacuum solenoid for the waste-gate. I have been reading about the rivet in the internal waste-gate and I'm not entirely convinced its the same problem, since it is said to go away once the car warms up and that is when mine starts making the noise....any suggestions?
not spark. I am almost positive the spark isn't the issue. Relatively new engine and turbo...less the 20k on both. I am leaning toward exhaust leak....going to the dealer again soon.
Thanks man. Yea the more I drive it the more it sounds like an exhaust leak of some sort....its only under a lot of torque, there in the engine is twisting more when the noise is present...2nd gear its there a lot and then 3rd gear it is quiet to almost no noise.
Hey there 08TCmavrk1181,
I hope that your next visit to your dealership goes well. If I can look into anything further for you, or if you would like for a case to be opened on this issue, please send me a private message with more information (including the last 8 digits of your VIN).
All the best,
Sarah
GM Customer Service
All the best,
Sarah
GM Customer Service
Well, I have heard of more than just my car having this issue. Not necessarily the same circumstances but definately the same noise. Search the forums and you will find others. If the dealer can't fix it I will be in contact thank you.
its for sure from the turbo....saw a thread about a small piece of metal in the turbo that rattles under boost. I think that may be it. car seems to be fine though no issues other than the noise
turbo and exhaust manifold both replaced as of 7-22-2013 noise was gone for the first day of driving. noise is now audible again. only thing i have done is drive it and put furl in it 91 octane
DANRICKARD
10-01-2015 01:08 AM
