Timing chain upper guide bolt broke
Old 05-22-2017 | 11:52 AM
WICobaltSS's Avatar
Hey all,
I'm doing the timing chain in my Daughter's 2004 Saturn Ion with a 2.2 after hearing a rattling noise. (157,000 miles, I figured it was time) Upon removal of the timing cover, I noticed the bottom bolt on the chain guide was loose and the upper bolt was gone. Can the stud be removed with a drill and stud extractor? How hard is this to do?
Thanks,
Jason
Old 05-22-2017 | 02:56 PM
jdbaugh1's Avatar
There are different extraction methods that I think would work because those bolts aren't installed with much torque in the first place. The main problem I think you would have would be accessibility to the top bolt with the engine in the car.
Old 05-22-2017 | 04:22 PM
WICobaltSS's Avatar
Yeah, that is the issue. I'll give the drill a try and hope it will reach. I'm hoping it isn't jammed in there.
Thank you.
Old 05-22-2017 | 04:56 PM
07blackg5's Avatar
Slobodan Milošević
Dorman # 917-954
Old 05-22-2017 | 04:57 PM
07blackg5's Avatar
Slobodan Milošević
The following 2 users liked this post by 07blackg5:
Slowbalt2000 (05-22-2017), WICobaltSS (05-22-2017)
