tranny leak
tranny leak
OK, so i have a small trans leak on my 06 ss/sc. its nothing major, just a little bit annoying. i was wondering if there is anything i can do(besides taking the trans apart to replace the seal, or tightening the bolts which ive already tried.)
heres a pic of where i have the leak at
no the clutch is fine. i bought the car with it. if the housing was cracked i would expect a pretty sizable leak right? i have looked at it pretty closely and it doesn't seem to be coming from higher up, although next time im under it ill defiantly make sure.
not necessarly, it could be a small crack, but the best and in my opinion the solution is to re-seal it if it is not cracked, a additive would just be a bandaid and would not be a longterm fix.
do you have any idea on the cost for a shop to do that kind of work, i think that would be a little over my head.
also, what is that seal called? anyone know?
Last edited by DeepBlack SS; 05-31-2009 at 11:15 PM. Reason: Automerged Doublepost
you know what. i think you might be right. when i got the car i noticed a little bit of wetness up there, at the time i thought it was just some water(had been driving in the rain) but that could be it.
