Transmission Issue's LOL
Think your having issues with your car? This is great..
Brought the Balt in on April 17 with a serious transmission whine.
Got it back May 13 with gear 3, 4, 5 replaced, new main output shaft bearing and some other trinkets replaced.
Car went back to the dealer May 29 with 3rd and 5th inconsistenly slipping out of gear.
Still dont have it back. The service manager at the dealer says that the GM tech's don't quite know what the problem is so the tech has been sending parts list's to the dealer to try on the transmission to get the issue fixed. Also, when you call to check up on the dealer after about 2 weeks, they tell you, "well we only have so many transmission guys around here and it seems to be an issue getting the work done at the moment". You must be joking.
Next, When you call GM customer service to see why they're doing trial and error testing on your transmission while also wasting your time, they don't answer or call back. Unless its 3 weeks later. Then they still dont have an answer for you and they can't figure out how to compensate you or correct the situation. WORTHLESS.
Does anyone want this thing when it's finally ready? You can have it at this point. I never ever want to deal with a GM product ever again. I was so in love with this thing for so long. Now I don't even want to deal with it because of the flag thats flying over it, i.e. GM. The whole situation is a joke. The customer service is a disgrace. Going on 8 weeks without the car.. The entire month of June on top if the 4 lost weeks prior.
Bullshit, no matter how you cut it. At least it's under warrantee. Yippee.
SHOULDA JUST PUT A NEW TRANS IN R-TARDS @%&$@^%$@.
That's odd they wanted to tear into it. But anytime transmission removal/break down is happening expect to be out of a car for awhile. With the trans slipping out of gear it seems like something was re-installed correctly.
