Trunk Ajar
Old 06-22-2016 | 12:51 AM
biniecki's Avatar
Trunk Ajar
I have seen a couple related posts from years ago but didnt have a clear answer. My car says trunk ajar everytime I turn it on. It is clearly closed and from time to time if i move the couple things that are in my trunk around the message will go away but not always. I hear there is some sort of sensor on the latch. Does anyone have a picture of this? Is this replaceable or do I need to replace the entire latch assembly?
Old 06-22-2016 | 10:33 AM
turbosmart4's Avatar
i would replace it. But remove it and clean it first and see if it helps. I had the same problem years ago, but mine was because it was misaligned and the plastic that goes on the wall wouldn't let the trunk close all the way... So I removed the plastic and problem was gone
Old 06-22-2016 | 03:04 PM
biniecki's Avatar
Is "It" the entire latch assembly or a sensor?
Old 06-22-2016 | 04:16 PM
The whole assembly
Old 06-22-2016 | 07:51 PM
real easy to get to and mess with, just take a closer look at it
Old 07-01-2016 | 01:46 PM
biniecki's Avatar
I looked at this the other day. Does the trunk lock need to be removed to be able to remove the latch assembly?
CudaJoe
40
08-16-2016 01:52 AM
LTBALTBMX
07-04-2016 01:33 AM
umrdyldo
07-01-2016 08:44 AM
KobaltSC
06-07-2016 03:12 PM
