Unknown Fluid Leak....HELP!!
I came home tonight and there are 2 wet spots on my garage floor, each about a couple inches in diameter. I looked at the fluid and touched it and it feels like a type of lubricant. It doesn't have much of a color, my mom said it is a very light green, almost like an aqua green. I compared this to the color of the coolant (redish) and the power steering fluid (bright green) and the washer fluid (blue) and none of these match the fluid on the ground. Does anyone know what this could be? Both of the spots are on the passenger side of the car, one by the front of the engine and the other by the rear.
BTW, I am not the best with colors because I am pretty color blind. Some colors seem different to me but I can compare colors and tell if they are the same or not. None of there colors are even remotely the same.
I have a white piece of cardboard under the car for the night so that will cath anything that comes out tonight.
If anyone knows what this could be, please give me a hint.
P.S I don't think it is oil either.
green stuff is an engine coolant. nothing else.
If my memory serves me right, your engine bay is concealed, so i'm not quite sure if you would be able to reach the hoses without rmeoving the plastic cover...but that would be what i'd look at first.
its probably blue washer fluid
gm uses red coolant, dexcool. not green. dont mix red and green either, by the way
theres not much on the passanger side of the car that could leak really, besides the washer fluid container. did you recently have any service done to your vehicle or anything?
about the fluid...i may be wrong....supercharger coolant or a/c compressor oil. make sure your a/c is cold and if not..it is prob that
I'm old school
A coolant leak may not leave a trace wet spot on the engine. Its water based, so it will dry up. The leak may occur only when the pump is running, so it won't continue after the engine is turned off. My money is on coolant.
Start the car and let it run parked. It should start the leak up again. Trace it while running.
There is still power steering fluid in the rack.
It could be compressor oil but I don't see that dripping in 2 spots. It is going to be really hard to see if the A/C is blowing cold when it is -14C outside, haha
The leak occured over night while the car wasn't running. The car is only running in the garage long enough to pull it in and out.
I am going to check the cardboard now to see if anything dripped in the last hour
Nope, nothing there. I will give you guys an update in the morning. Thanks for the input so far!!
i forgot to mention, for the past few years gm has been putting black light dye in some fluids. a/c compressors almost always have it and power steering has it sometimes, but not always.
i promise you it isnt coolant though
aaand as i keep typing i keep remembering things. have you used your defrost lately? that will turn the a/c compressor on too..
Open your hood and look at the coolant. GM coolant (DexCool) has been red/orange for a long ass time.
Well, nothing driopped over night so I don't know what the hell it was. I am pretty sure it isn't coming from my car, unless it is A/C lube or something. Oh well, I'll leave the carbboard under the car for the next little while and see if anything else comes out.
