unleaded fuel
unleaded fuel
i had 25% of premium then i went to the gas station and made a mistake of putting the cheap **** in for the other 75%. is my car going to be ok? what should i do? i feel like a dumb ass lol i was wondering when i was done how it only costed 14.00
u should be fine...........if your really worried just siphon that **** out and use it for the lawn mower........you will hear a knocking noise in the engine though since the the octane rating is below par
its fine dude dont stress you probably will hear a slight knock but once you run the gas out and refill it with 193 it will be ok...and FYI you havent been able to siphon gas since like 85 if you could i wouldnt ever buy gas again.
It would be bad if you never put 93 in it ever again, people borrow my car and now matter how many times I say it takes premium they always fil it back up with 87, it's at the point if you need it I will fill it up and don't worry about addinggas if you can't get the right kind.
its all good man. your car won't like it much, and I'd stay away from loads of boost, but the car will be fine. the day I drove my car off the lot, I told the salesman NOT to put the shitty fuel they fill new vehicles with in my tank. this statement was laughed at, and I was basically ignored. sure enough they filled er up with 87octane. the car ran fine, untill it hit 4200 RPM and it would then just give up. it was like i would hit a rev limiter right there, and that was all she would give me. once I burned off all that low grade gas, and topped it up with premium, the car ran fine. just go easy on it untill you can get a full tank of the good stuff in there.
there's knock sensors in place so as long as you don't drive ***** to the wall you'll be totally fine. gas mileage may suffer a little, other than that no problems if you take it easy.
You can add octane level booster till u burn that tank then go back to premium and premium is only recommended doesnt need to be used. will possibe cause a ping due to poor combustion pre detonation......... premium is only 91 octane its not like ur car is meant to fun 103 octane haha then **** would **** up
Also ur not running any stage upgrades either?
you can siphon gas from any car wtf are u talking about?
Drive easy till the car gets below half a tank then put 93 octane in and you will be fine.
Do not use octane boost, it is a total rip off. A bottle of octane boost *MAY* raise your octane by 5 points, which is .5. You would need to put in 4 bottles of octane booster to even raise the octane enough to make a difference.
