Vibrating?!
Vibrating?!
When I was driving home from college, I noticed my gas pedal and brake pedal were vibrating, along with my steering wheel. My steering wheel was a little more than usual. What could make this happen? Even touching my door when driving I feel it vibrating a little.
Anyone know the cause of this?
I went under the car again. Found the problem. My exhaust came loose and was hitting the frame also. Hopefully this will stop the problem. Going to put it on the highway to see if it's still vibrating. Going to
Weild it differently so it won't come loose or hit.
I talked them about balancing them, they said they were.
How can I check from defects in the mounts?
Here it goes, if im parked I feel it a slight bit. When I put it in drive or reverse it gets heavier. When I start going faster the vibrations become worse. What are all the possible things to make this happen?
The things I have done to my car that could probably affect it. I have 17 inch rims, catback exhaust. (Megan Spec Drift), eibach sportlines, camber kit, and steering rack spacers.
I can even feel the vibrations holding my shifter.
I wish I had the supplies to check everything myself. Taking it
To same place as last time. Hopefully they can listen to me when I kept listing things that couldne wrong. I checked my engine mounts. They look fine. They actually look new. I'm thinking something
Came looose in my engine. But when I put it in gear. It only shakes a little. When I drive it shakes more. Which makes me think it's my lowering springs, axle, bearings, or my tire. Since I been hitting so many potholes.
Did you check the trans mount.
The motor is vibrating from the sound of it. If you lift the hood with the car on does it vibrate slightly? Have a friend rev the motor and see if it moves. Tell them to put it in gear and see if it moves.
tell them to test drive the vehicle. If the exhaust is really causing, then its because the exhaust is putting tension on the engine.
They checked and I checked. Engine isn't moving. I had my exhaust for months and no problems. They checked the exhaust yesterday. It was loose and
They welded it different to make it fit better. It's a loud exhaust. But I don't think
That's going to shake my steering wheel and gas pedal. I drove a truck with no tale pipe and no shaking. If it was the exhaust it would either be a leak or what you said.
