vibration help
vibration help
ok since i got my car back from being fixed it has a vibration not awful but annoying but its a weird vibration... between 30-65 it vibrates when on the throttle in gear all gears first-fifth. push in the clutch when its vibrating and it stops. could my transmission be messed up? my drivers side wheel is what hit the other car and bent the control arm back about 3 inches. please help me figure out whats wrong
Could be tranny issues,
But
Things usually are never right again after front end damage like that in most cases.
The way the cars are built(no real frame)nowadays you will probably have to live with it.
Keep bringing it back to who fixed it until they hopefully can resolve the issue.
Did the replace the tire and the rim in the repair?Either could be damaged
rotate fronts to back and see if it changes anything.
But
