Vibration Idea - Confirm my theory
Hey guys, so had bad vibrations. cut the drums, replaced the warped rotors. most of it went away, now there is a little between 45-65 or so...
I am thinking wheels out of balance... they were mounted last summer.... anyone wanna confirm my suspicions?
Buehler?
Buehler?
my car vibrates at 2500 rpms and its something related to the motor....no clue what tho
one only needs to watch your videos to see why
hack, when you said bearings not too long ago but mine have nothing to do with turns its just when im traveling around 45-65 and then above the vibes go away.
Yeah defintely sounds like a wheel is out of balance when it gets the vibration right around 60. I have this problem right now myself, but the next thing i would suspect is a shifted belt on one of the tires, especially if they are older tires with a lot of wear, I've had that happen in the past where i thought it was the wheels needed balancing.
