What does this code mean?
the second digit indicates if it's SAE or M.S.
you said the code was p I D 1 0 T
the second digit in said code is "I", which instantly tells you that it's a fake code (i.e. it doesn't exist)
Examples of a real code:
p0300 = Random Misfire (notice the 2nd digit is a "0"? that means it's SAE)
Haz l33t wheelz.
like i said, it was probably a slow day and they probably wanted to have some fun. IDK, can't speak for the dealership. I know I use to do it all the time with customers that thought they knew what they were talking about when I worked at NTB.
#37
Well what the hell.
I had this same issue but I don't have those mounts you speak of.
Ugh. And to top it off I am getting the display again, "Check Gas Cap"
I get out and look, it's shut all the way. I dunno qwik.
#41
Haz l33t wheelz.
Your fingers are too cold, you are not used to the low temps where you are. Warm your hands in hot water, then try tirghtening the gas cap again. Normally its the vibes from those mounts you got that set the code...
#43
#45
Haz l33t wheelz.
I am actually waiting on some rotated mounts from OTTP, but i don't see what that has to do with this code. i don't remember seeing any sensors or anything like that on the mounts. How would it know?
#48
Haz l33t wheelz.
Haz l33t wheelz.
