What does this code mean?
#51
And I'm too far from blazin. There's no way the filler neck for the blinker fluid is there.
Seriously, I need some help with the blinker fluid. I read somewhere that it will start causing bulbs to burn out really fast.
#52
There is a plastic strap on the inside of your gas cap..you have to screw it shut through the door. If your missing this you can probably find it on ebay for a few hundred bucks.
#55
So you're saying if maybe I held my hands up to the vents it will warm them up enough to tighten the gas cap properly?? I thought the code meant the gas flap thing on the car......
#56
Haz l33t wheelz.
#59
#60
Haz l33t wheelz.
Now you are making this personal I want piktars of Rydis strap on dick and I will show you where to put it....
#64
Haz l33t wheelz.
I'm gonna start reporting posts, this is outta hand.
#65
I did. But for some reason the code won't clear. Or so GM told me.
And why would they lie? They have no reason to.
Where can you pick one up at?
I think so too.
We are trying to resolve a serious issue and can't.
Typical of this damn website.
bunch of fgts.
bunch of fgts.
#66
you pick them up at hollywood and vine, and did you never hear of gay pride. we are a bunch of fgts and proud of it...STOP it now...
#70
#72
GRABBER BLUE MUSTANG GT
BULLETIN FROM GM!
Pipe At Fuel Tank - keywords lamp leak line,gas cap loose and/or low blinker fluid - (Aug 4, 2006)
Subject: SES Light due to a P-ID10T DTC
Models: 2006-2007 Chevrolet Cobalt, Cobalt SS
2007 Pontiac G5
2006 Pontiac Pursuit (Canada Only)
2006-2007 Saturn Ion, Ion Redline
This PI was created to include 2007 Models.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
On rare occasions, a SES light may be experienced due to a P-ID10T DTC.
Recommendation/Instructions:
If the SI diagnostics do not isolate a cause for this concern, inspect the accordion style EVAP line shown below for a small hole. If a hole is present, it will be necessary to enlarge that hole on the fuel tank since this line is not serviced separately.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
All rights reserved.
2007 Pontiac G5
Condition/Concern:
#73
BULLETIN FROM GM!
2007 Pontiac G5
Condition/Concern:
2007 Pontiac G5
Condition/Concern:
