Where is the MAP lights fuse?
I turned my car on after work last night and my odometer/spedometer and a/c controls didnt light up...i have alot of electrical **** in my car so i figured i just blew a fuse...i looked at the interior fuse box and the one under the hood and cant find any blown fuses or anything labeled map lights?
anyone know where its at?
AWD > FWD
You're talking about the lights in the mirror right? That's on the #27 fuse inside the car, it's labeled interior lights. Controls the lights in the mirror, a dome light, the light on the shifter if its auto, etc. basically all the lights in the interior except the ones on the steering wheel, that's separate. Does your gauge cluster and hvac controls still work? if not, you blew the fuses for those, which are seperate. Try checking the steering wheel illumination fuse too, that could possibly work those, but I don't think so. It's #28
i always thought they were called MAP lights but I guess not.
Brick, check your tail lights.
The fuse for the cluster lights gets it's power from the fuse for the tails so if the fuse for the tails blows the cluster lights go out too - lets you know there is a problem since you can't see the back of your car while driving.
Believe it is labled PRK LMP.
