08 Recall
Tried just driving in the snow today in ct, and when I nearly slid into a curb, I put it away and drifted with dads car instead.
I dunno....in all my years working at a dealership, I've managed not to mess up anyones car.....but eh I guess accidents do happen. As long as they weren't doing things they shouldn't of been anyways
This is it guys... (and gals)
#07255: Customer Satisfaction -- Coolant Leak - (Oct 4, 2007)
Subject:07255 -- Coolant Leak
Models: 2008 Chevrolet Cobalt
2008 Pontiac G5
THIS PROGRAM IS IN EFFECT UNTIL OCTOBER 31, 2008.
Condition
On certain 2008 model year Chevrolet Cobalt and Pontiac G5 vehicles, the hose connecting the surge tank to the thermostat cover may not seal sufficiently. This could result in a coolant leak at the thermostat cover. If enough coolant leaks out, the engine coolant temperature warning light will illuminate. If the vehicle is driven with the light illuminated, it could result in engine damage.
Correction
Dealers are to install an additional clamp to the hose at the thermostat cover.
Vehicles Involved
Involved are certain 2008 model year Chevrolet Cobalt and Pontiac G5 vehicles built within these VIN breakpoints:
2008 Chevrolet Cobalt 87100001--87125118
2008 Pontiac G5 87100006--87125081
Important: Dealers are to confirm vehicle eligibility prior to beginning repairs by using the GM Vehicle Inquiry System (GMVIS). Not all vehicles within the above breakpoints may be involved.
For dealers with involved vehicles, a listing with involved vehicles containing the complete vehicle identification number, customer name, and address information has been prepared and will be provided through the applicable system listed below. Dealers will not have a report available if they have no involved vehicles currently assigned.
-- US dealers - GM DealerWorld Recall Information
-- Canadian dealers - GMinfoNet Recall Reports
The listing may contain customer names and addresses obtained from Motor Vehicle Registration Records. The use of such motor vehicle registration data for any purpose other than follow-up necessary to complete this program is a violation of law in several states/provinces/countries. Accordingly, you are urged to limit the use of this report to the follow-up necessary to complete this program.
Parts Information
Parts required to complete this program are to be obtained from General Motors Service and Parts Operations (GMSPO). Please refer to your "involved vehicles listing" before ordering parts. Normal orders should be placed on a DRO = Daily Replenishment Order. In an emergency situation, parts should be ordered on a CSO = Customer Special Order.
Part Number
11571080 Clamp, Rad Surge Tk Otlt Hose
12346290 - US Coolant, Eng (Extended Life) (DexCool)
10953464 - CN As Needed
Service Procedure
1. Remove the engine cover.
1.1. Unscrew the oil cap.
1.2. Pull upward on the cover to unseat the cover from the pins.
2. Open the spring clamp and push the hose fully down to the thermostat cover housing.
3. Install the hose clamp.
3.1. Open the hose clamp fully, disengaging the worm screw.
3.2. Slide the hose clamp over the surge tank outlet hose.
3.3. Hand-start the worm screw to engage the hose clamp over the hose.
3.4. Position the hose clamp along the top of the existing spring clamp. The screw head should be on the outboard side of the hose and facing forward.
3.5. Tighten the hose clamp. Keep the two clamps beside each other but with no overlap.
4. If the surge tank fluid level is below the cold full line, top it off to the line with coolant.
5. Wipe any spilled or leaked coolant from the engine and engine compartment.
6. Replace the engine cover.
6.1. Engage the two pins.
6.2. Replace the oil cap.
2008 Pontiac G5
Condition
Correction
Vehicles Involved
Parts Information
Part Number
Service Procedure
satisfied
10-19-2015 01:35 AM
