boost problem
To add to the turbo problem has anyone been having there turbo cutting out at 5psi? go to fifty mph in fourth and put into fifth gear and drive up to sixty mph just like normal driving and getting up to speed then when you reach speed feather your foot out to stop accelerating and the turbo with cut out and you can see it on the boost guage and can feel it in the car it only happens at 5 psi it almost like the turbo is smaking the housing or the is turbo lag. Took it to the dealer and tech said he didn't know wat it could be. Also when you get on it in 5th gear the turbo builds up to 10psi and my foot is mashed down the whole time it with go to ten real quick then go to 5 then ten again when it should maintain a constint boost anyone having this problem to? Its a 08 SS/TC anyone having the same prob or suggestions? i need to know so i can get this fixed.
