Recalls Chevy Cobalt recall information center
power steering fail after recall.
Old 02-06-2015 | 02:43 AM
06cobalt racer's Avatar
they told you that yours isnt covered? i though all cobalts were covered?
Old 02-07-2015 | 12:52 AM
ForsakenOutlaw57's Avatar
Originally Posted by SLRdohc
mine has been out for awhile. has soon has I turn the wheel it goes out. So been pretty used to the non power steering crap. Getting ready to replace the motor unit soon. Hopefully it is that. Found the PS motor on ebay for 90. My vin doesnt check out has a PS recall which is BS> oh well
I don't think it's the actual power steering motor, I think it's something bigger. I had the recall done and this is what I get. It feels like it's a larger, electrical issue. Here are two videos of what my gauges do if anyone is seeing something different. I tested the odometer with mile markers and that is working but everything else is useless and no I do not have power steering during this time. It's murder on the side streets and it's noticeable on the highway too.
Old 02-11-2015 | 04:42 PM
Update
Just got my car back. It was the power steering motor that went out. They replaced the motor for free. So far so good. I will update again later and let you all know if it is fixed for good.
Old 02-11-2015 | 07:16 PM
Sounds good - time to make that phone call.
Old 02-11-2015 | 07:18 PM
Old 02-11-2015 | 07:32 PM
Trav3480's Avatar
I just had my ignition recall done , now my airbag light comes on . To test dealership wants 90.00
Old 02-12-2015 | 04:18 AM
yes it is
awesome!
wow really? if it started coming on when they did the recall they should test it for free!
Old 02-12-2015 | 06:12 PM
SLRdohc's Avatar
I thought so too...
Car Gauges #1 - YouTube
Car Gauges #2 - YouTube
Holy crap mine does nothing like that at all.
Old 02-12-2015 | 06:34 PM
rains_crusader's Avatar
I don't think it's the actual power steering motor, I think it's something bigger. I had the recall done and this is what I get. It feels like it's a larger, electrical issue. Here are two videos of what my gauges do if anyone is seeing something different. I tested the odometer with mile markers and that is working but everything else is useless and no I do not have power steering during this time. It's murder on the side streets and it's noticeable on the highway too. Video Link: http://youtu.be/AyMRKJ_5fG8 Video Link: http://youtu.be/mHgrkfS3jW8
Check your vehicle speed sensor (VSS). If it's causing problems, you should have DTC C0000. Also check your splice pack for GM LAN. Make sure all connections are tight and aren't corroded. It's located behind the cubby where the trunk release is. It's a small flat plastic block with several green wires feeding into it.
Old 02-19-2015 | 04:51 AM
well i have driven about 500 miles and so far so good. the steering hasnt gone out once since i have gotten it back!
Old 02-24-2015 | 02:05 PM
  #36
good to hear
Old 09-22-2015 | 09:19 AM
  #37
spottykat13's Avatar
Exclamation power steering issue
Alright so here is my problem that I have been fighting with GM for. My cobalt already had the power steering assist transmission motor I believe its called fixed. Well this was before I owned the car. Well we ran the car on the scanner and its coming back with the code for that failing again. GM is claiming they will not fix it again unless if we can prove it. Any ideas on what I can do to get it to go forward? Also the dealership lied to my face when they had the car for 3 days trying to get it to do what it had done for me but they told me there was no codes coming up. Meanwhile my boyfriend who is an entry level tech it took him like 10 mins but he went into the computer and found a code right away. In theory sorry if this is jumpy I'm just looking for info on how to fight GM to get this issue fixed again because I'm kinda concerned for my safety here and driving the car.
Old 09-22-2015 | 10:48 AM
  #38
Dipped_Cobalt's Avatar
cant you just show them the scanner?
Old 09-22-2015 | 02:56 PM
  #39
It was done by my bf at a different dealership. But we took the code we got and printed out the info given online about that code and gave it to them.
Old 09-22-2015 | 03:01 PM
  #40
and they cant pull up the same codes your bf did?
Old 09-23-2015 | 06:16 AM
  #41
They lied straight to our face when we asked if there was a code. We are going to a different dealer and see what happens. GM says we have to p[rove the part is bad in order for them to pay for it. But if the code is coming up then wouldn't it be bad?
Solaris99
28
03-15-2017 02:22 PM
Zharrington_2010LNF
02-08-2016 02:43 PM
TedSS
26
10-10-2015 05:30 PM
Stuff
10-01-2015 06:47 PM
09-26-2015 07:44 PM
