Recalls Chevy Cobalt recall information center
recall problem, any one else have this?
Old 04-15-2007 | 09:26 PM
chevysalesman614's Avatar
since the recall was done, today was the first substantial rain...
right around the a-piller on the passenger side, and my sunroof button, there are big wet spots ( I mean totally dripping)
WTF?
Old 04-15-2007 | 09:29 PM
KillerBee's Avatar
i have not had no leaking on mine was it raining hard or what
Old 04-15-2007 | 09:30 PM
RollOver360's Avatar
What recall are u talkin about? The headliner where they add foam? If its leaking, somethin def wasnt put back together right, take that back asap.
later
Old 04-15-2007 | 10:14 PM
Coblasts's Avatar
I think that would be your sunroof leaking.
Old 04-15-2007 | 10:17 PM
mken's Avatar
I asked my dealer about that recall and they pulled some documentation up on their computer to show me what was done. As far as I could tell they just pull the headliner down and hot glue a small piece of padding by the visor and then put the headliner back up again. If they caused a leak when doing yours, they did something very wrong.
Old 04-15-2007 | 10:18 PM
NKs07CobaltSS's Avatar
Keep taking it back! my freind has had 3 sunroofs put in his 06 SSC and they had to warrenty it for life of the car. He is getting rid of the car because of it. Its definetly a big problem GM has!
Old 04-15-2007 | 10:20 PM
vacobaltss's Avatar
i cant remember exactly what it says, but i do remember seeing a bulletin the other day about a water leak from the sunroof/headliner area. id just take it back and tell 'em to check for the bulletin.
Old 04-15-2007 | 11:08 PM
Halfcent's Avatar
I'm old school
There is a TSB for leaking around the sunroof button. Sounds like when they had you headliner off, they triggered the issue that causes the leak.
Your recall repair has nothing to do with the leak other then being in the same place. Take it back and ask about the leaking sunroof switch TSB.
Old 04-16-2007 | 07:16 AM
it never leaked b4 the recall
TSB? I dont know what u mean. what about the a pillar passenger side?
Last edited by chevysalesman614; 04-16-2007 at 07:16 AM. Reason: Automerged Doublepost
Old 04-16-2007 | 07:41 AM
takes5tries's Avatar
glad i dont have a sunroof
Old 04-16-2007 | 08:56 AM
silversccoupe's Avatar
Here in Wash. I think it's called a rain roof.
Old 04-16-2007 | 12:32 PM
anyone know what he meant by TSB?
Old 04-16-2007 | 12:40 PM
Halfcent's Avatar
I'm old school
Technical Service Bulletin. They are specific service instructions about known issues on the cars. All GM cars have a list of them that the technicians are supposed to use to repair certain problems. We (the site) are in the process of making a new section listing them all. Certain popular items are the door trim cup fabric issue, the sunroof trim ring falling off, the leaking sunroof (yours), and the steering column clunk. There are lots more.
Old 04-16-2007 | 12:41 PM
SSdan's Avatar
Technical Service Bulletin. There IS one out for leaking sunroof.
Old 04-19-2007 | 02:36 PM
fr33k's Avatar
Here's the TSB for the sunroof leaking. When the dealer installs the head restraint recall, they shouldn't of done anything with your sunroof but maybe open it.
A TSB is information for the techs to help diagnose what is wrong with a vehicle. TSB's are not free repairs if your car is out of warranty. A recall/campaign is something GM knows has a safety issue and will pay for repairs even if it's out of warranty.
Document ID# 1875772
2007 Chevrolet Cobalt
Subject: Headliner Wet at Center Map Light/Sunroof Switch Area (Adjust Sunroof and Apply Lube) #06-08-67-019 - (12/05/2006)
Models: 2005-2007 Chevrolet Cobalt
2005-2006 Pontiac Pursuit (Canada Only)
2007 Pontiac G5
2003-2007 Saturn ION
Condition
Some customers may comment that the headliner is wet or damp in front by the map light/sunroof switch.
Cause
This condition may be caused by the sunroof being out of adjustment in the front. This causes water to get past the seal and wick though the conduit pipe, dripping on the map light /sunroof switch and the headliner.
Correction
Adjust the sunroof following the procedure below.
1. Open the sunshade.
2. Close the sunroof glass.
3. Loosen the adjustment screws.
4. Adjust the front of the sunroof glass flush to 0.5 mm (0.02 in) above the roof panel. Tighten the screws.
5. Adjust the rear of the sunroof glass flush to 0.5 mm (0.02 in) above the roof panel. Tighten the screws.
6. Open the sunroof.
Apply Super Lube® to the sunroof cable where it enters the conduit pipe (as shown in the illustration above).
Return the sunroof and sunshade to the close position.
Parts Information
Part Number
Description
12346241 (U.S.)
10953474 (Canada)
Super Lube®
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B2720
Panel, Sunroof - Align
Use Published Labor Operation Time
Old 09-17-2007 | 02:56 PM
GSMiller's Avatar
Ditto.
I am affected by the 07 recall though. Yet to receive a letter. I'll just mention it when I take it back to the dealer for an oil change.
Old 09-17-2007 | 03:48 PM
SSROMER's Avatar
WTF?
had a couple of friends with that problem they ended up giving them a new ride one with out a sun roof one of them got it fixed no problems ever since
turbochargedss2012
09-20-2023 01:17 PM
yellow dragon
09-28-2015 10:49 PM
Iceberg
09-28-2015 02:31 PM
DocSvensk
09-27-2015 03:24 PM
Adiaz1ss
09-27-2015 12:51 AM
