engine bay dirty... need help
What you are seeing is not really cleanable. Its basically... Oxidation? The solution that most people take to amend that is to remove parts and paint them lol.
However before going that route it does help a little to get a wire brush and some brake/engine cleaner and get with it
I like simple green, and simple green max automotive degreaser
Both work amazing, they are also both great for cleaning dirty tires and fender wells.
Also works great on stubborn brake dust, but brake dusts a bitch.
I think a lot of people miss this, which is why it is extremely important to only do the engine cleaning on a cool engine and you don't let it dry on there. Rinse the engine, apply cleaner, scrub engine then rinse off.
Staged07SS (04-19-2016)
Over the summer I had an experience with this and I found a way to brighten the blower up, but it stained some of the plastic like the engine cover and etched spots into the clear coat on the coil cover.
What I did was cover the engine and used mag wheel cleaner on the blower housing – I don't recommend it.
Were I to do it all over again, I would just accept the blower corrosion, clean the bay, and call it done.
I'm still hunting for a good engine cover to replace my stained original.
Here are some links to the posts I wrote about it:
Cleaning the Cobalt's Go Parts
Engine Cleaning Oopsie
Day 6: More Clay Barring for the Cobalt
Down the Homestretch
If you're interested, I documented the rest of ordeal as well.
The blower did end up looking nice, but it wasn't worth the damage or potential damage to everything else under the hood.
Last edited by hrspwrjunkie; 02-09-2019 at 02:39 PM. Reason: Didn't mean to come across as laughing in anyone's face.
The absolute best way I’ve found to clean my blower is simply goin at it with a steel wire brush. Got one from autozone for $3 and had that thing sparkling. As for the block, I haven’t really done the best with the brush, it doesn’t work the same, so the above mentioned products are probably better to use.
AfterShok (01-12-2021)
BoostedCobalt22
10-21-2008 08:41 PM
