I think my catalytic converter died on me tonight
Old 09-24-2016 | 11:39 PM
OzzyruleZ's Avatar
Took the car to the track for the first time tonight. When we first got there it was hotter than Hades anus. Car wasn't to thrilled neither was my friends M62 LD9 Cavy. Our cars are pretty neck and neck. Both trapping about identical speeds. However as the night progressed and got cooler he got quicker. Not me though. Mine kept slowing down.
Then during a pass middle of 3rd gear it just fell on its face. Like bad, I was expecting to see "reduced engine power" come up in the DIC but it never did. No check engine light, gave the engine a visual once over and couldn't find anything out of place. The car developed a hesitation off idle too. I let it sit a while and then made another pass to see if it was just a hiccup. I lost over 4mph in trap speed and 6 tenths ET. Boy was it sluggish as hell.
So I figured maybe MAF, possibly TPS or even the TB. But then on the way home from the track I got on it and happened to glance at the boost gauge. It was above 16psi and I'm on a stock pulley. It doesn't smell bad, but the cat letting loose would definitely cause that and it's lack of power.
Any of you guys have any thoughts?
Old 09-25-2016 | 12:51 AM
could be. after driving it hard have a look under it and see if the cat is glowing, thats a sure sign its toast. helps if you do this at night
Old 09-25-2016 | 01:22 AM
OzzyruleZ's Avatar
OK I'll give that a shot tomorrow or Monday. Was also reading it could be a lash adjuster. Hopefully not.
Old 09-25-2016 | 06:53 AM
It would probably be missing if you had a broke lash adjuster, if its still running fine id say cat.
Old 09-25-2016 | 07:46 AM
06blackbalt's Avatar
Could be lash adjuster my lsj did that one time was boosting 20psi on the stock pulley one day an it kinda sounded like a Subaru when it happened pull your valve cover an check the exhaust side
Old 09-25-2016 | 10:30 AM
Tdubbs's Avatar
Quick test to see if your cat is plugged, pull the upstream o2 sensor and go drive it. It's gonna be loud but if it seems to pull harder again you have your answer.
Old 09-25-2016 | 12:12 PM
OzzyruleZ's Avatar
I just got finished tearing the valve cover off, everything looks good there. So I put it back together and started it up. I had it running a bit and gave it a couple small revs. I could smell something faintly so I walked around the back and found crap shooting out the exhaust lol. I think it's safe to say it is the cat dying.
Old 09-25-2016 | 02:55 PM
Looks like a dying cat
Old 09-25-2016 | 03:00 PM
cluelessk's Avatar
You just gonna punch out the rest of it?
Old 09-25-2016 | 03:15 PM
OzzyruleZ's Avatar
The car has a full ZZP exhaust so I'm thinking I might just buy their test pip to put in
cluelessk (09-25-2016)
Old 09-25-2016 | 05:42 PM
Cool glad you figured it out
Old 09-25-2016 | 08:52 PM
el gato
Old 10-04-2016 | 03:25 PM
dlhiser's Avatar
I had a problem with my stock cat recently.The car would basically lose power and shut off.I took the down pipe off and it sounded like glass in a bag when I shook it.I ended up knocking it out.I have been
driving it ever since.Other than it is a lot louder,will it damage anything without the cat?
Thanks
Old 10-04-2016 | 03:44 PM
JapEatr's Avatar
South Central *********
no damage, just CEL until you turn off the code
Old 10-05-2016 | 02:00 PM
dlhiser's Avatar
That is the answer I wanted.THANK YOU
Old 10-06-2016 | 07:21 AM
Staged07SS's Avatar
Administrator
Administrator
Yup, bye bye cat.
Time for a catless setup
315SS
11-01-2016 04:23 PM
sinisterSF
08-27-2016 08:33 AM
Quick Reply: I think my catalytic converter died on me tonight
