Super budget build Redline
#85
Thermostat took a ****. My luck. Turned car on today. Nice big ol check engine light. Dang thermostat code followed by a lean code and a weird code known to Redline's about the intake. Oh well getting new thermostat asap and doing it. Keeping my eye on you little redline
#87
This project was more of a headache than anything. The rotors wouldn’t go on. It was a very tight squeeze for the hub to go on. Wheels don’t fit.
Ended up grinding the rotor hole wider. Not much. Grounded the wheel a bit. Was not enough. Ended up adding 10mm spacers on the front. For both sides. C clip clipped off on the driver side axle. Had to get a replacement as it did not want to go together. Raised the car up a bit. No rubbing. ABS is still not on. The rear hubs are lnf and need lsj hubs. Totally forgot to snag them. I’m an idiot.
Small vibes at 80mph. With how much **** I did up front. The small vibes ain’t squat. Like it’s barely noticeable
#88
We had a nice little snow storm. I had to drive the Redline thru it. Let me tell you!!!! This thing is a beast. With the tires being new and this little car being low. It made the drive of 2.5 hours in the storm a breeze. I was doing 75-80 the entire time. Handling it no issues. Def was a fun time. When I got home. They didn’t plow my street. I tested the car there and it was AMAZING!
#96
Budgetline has been real good to me reliable wise. I needed a bigger work vehicle and well there it is. HHR SS has replaced the Redline as a work vehicle. Redline is sitting at 119k miles and I’m going to drive it 1 more month ish to put just enough miles to do another oil change. She will be going up for sale soon. After I replace the engine harness with a wire tuck harness and doing a sneaky 2.7 pulley mod. Hehe.
